1986 Ford Bronco will not start occasionally
JOHNNY13
1986 Ford Bronco V8 Four Wheel Drive Automatic
my 86 ford bronco will ocassionally not start. it will turn over just fine but it wont start. this seems to happen when it gets warm. after letting it sit for a few hours it will start just fine.
Apr 26, 2009 at 10:04 AM
  • 75,988 POSTS
When it does this don't wait do below to determine if its fuel or spark problem and comeback with some results.
Get a starting fluid/ether/better off gas in a spray bottle and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, ECM,Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time/broken or jumped timing belt/chain
Apr 26, 2009 at 10:09 AM
JOHNNY13
used ether, didnt start. checked for spark to the distributor and from the distributor to the spark plugs and there was a spark. today i actually pulled the fuel injectors, cleaned and tested them and they worked fine. havent checked the valve and ignition timing yet. this is the ohly vehicle i have so i have to do all my work on the weekends when i make time, so sorry for the delay.
May 3, 2009 at 12:43 PM
