1986 Ford Bronco two metal lines running from transmission
1986 FORD BRONCO
SPICEY BACON
Transmission problem
1986 Ford Bronco V8 Four Wheel Drive Automatic
what are the two metal lines running off the transmission to a box that is mounted in front of the radiator called . ( got a leak in one and was wondering what they are called and where i can find one .
Jun 19, 2008 at 6:59 AM
DOCFIXIT
  • 18,828 POSTS
Those are the transmission cooling lines very important if leaking replace a.s.a.p.
If you want the exact line the dealer you will have to go. Or you can buy the line and with finess bend it to fit.
Hope this helps
Jun 19, 2008 at 7:11 AM
TRIPPA
If you plan on doing a lot of line replacements, brake, transmission, or fuel lines in your life time you should purchase a line bender. I bought a good one for about 20 bucks, don't buy the cheap ones, remember you are going to be using it everytime you want to replace a line. My method is to remove the old line and mimic the bends as close as possible. No 100% as accurate as purchasing pre-bent lines, but close enough to only need a tweek here or there.
Apr 24, 2011 at 6:20 AM
