1986 Ford Bronco starting problem
116,000 MILES • 6 CYL • 4WD • AUTOMATIC
TAYLOR C
I just bought a 1986 ford Bronco 2. It wouldnt run at all. I replaced the fuel filter and it started but I had to pump the gas to keep it running. What's wrong. I have replaced a few things but it still needs the gas pumped to keep it running but it wont stay running after you stop pumping the gas.
Jul 28, 2008 at 11:55 AM
  • 75,988 POSTS
Inspect and test the idle speed control air bypass solenoid and throttle position sensor and check fuel pressure.
Jul 28, 2008 at 12:20 PM
