1986 Ford Bronco stalling/ surging problem.
348,692 MILES • V8 • 4WD • AUTOMATIC
JUSTIN_RANDALL
Hi, My problem is that when you rev the truck up it will cut in and out but won't completely stall. It runs fine at an idle hot or cold, only when you try to give some throtle does it do this any ideas?
Justin
Jan 2, 2009 at 9:27 AM
  • 110,248 POSTS
Justin, does the engine have a carb or fuel injection?
Regardless, I would start by making sure the carb / throttle body is tight. Also, make sure there are no vacuum leaks.
Let me know what you find.
Jan 4, 2009 at 6:07 AM
