1986 Ford Bronco not geeting fire to plugs.
JONDEGRE
  • 1986 FORD BRONCO
Engine Mechanical problem
1986 Ford Bronco 6 cyl Four Wheel Drive Automatic 10000+ miles
well lets see I got the bronco 2 from my buddy it did not run when I got it he said he was driving and the moter just quit wuld turn over all day just would not fire so I got and checked the coil had fire coming from it just not to the plugs so I changed the distributer and still no fire it has new pugs and wires pleas help I dont know whare to go from here thanks.
Thursday, October 1st, 2009 AT 6:24 PM
  • 109,772 POSTS
If you are getting spark from the coil, then the problem is in the distributor. Remove the distributor cap and have a helper crank the engine. Is the rotor turning?
Friday, October 23rd, 2009 AT 11:54 AM
REBOOM
  • 6 POSTS
Is there an ignition module. It would be on the dist. If there is you can take it off and auto zone can check it. But if it is bad and you get a new one have it checked also before you leave store. Happened to me. I bought a new one put it on but same problem. The new one was no good. You might also have to by a tool to take it off. Good luck.
Monday, November 2nd, 2009 AT 3:59 PM
