Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Bronco
Climate Control
Heater
Not Working
1986 Ford Bronco Heater and overheating issues
1986 FORD BRONCO
60,000 MILES • V8 • 4WD • AUTOMATIC
BROKENBRONCO
MEMBER
1 POST
The engine runs hot, but the heater blows cold. I've replaced the thermostat, and flushed the radiator. Could it be a wiring issue?
Jan 21, 2009 at 2:42 AM
Experienced Mechanic
Hi:
It sounds like the radiator is still plugged. You may want to consider having it rodded out. Sometimes spraying water through it isn't enough.
As far as the heat, are both heater core hoses getting hot when the engine is hot, running and the heat is on?
Jan 22, 2009 at 12:36 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
