I have an 86 ford bronco with a 5.0 fuel injucted engine automatic transmission. Around 140000 miles. When the truck is cold it runs fine, great even. After driving it for about 20 minutes and the engine warming up to regular operating temp. It starts to cut out, sputters, hesitates when you try to accelerate. Any ideas?
SPONSORED LINKS
Monday, January 19th, 2009 AT 10:24 AM
MIKE H R
MECHANIC
When was the last time the fuel filter was changed??
Wednesday, January 21st, 2009 AT 9:03 AM
JAMN84
MEMBER
New fuel filter and pump changed when it started, new o2 sensor, EGR has been checked, new map sensor, Cats have been removed, new distributor and coil
SPONSORED LINKS
Wednesday, January 21st, 2009 AT 9:47 AM
MIKE H R
MECHANIC
Have you checked the vacuum lines? Not much on computers but try resetting the computer. On that year you should be able to reset it by just disconnecting the negative side of the battery and after a few minutes reconnect it. It might be something in the computer that is causing the problem.
