1986 Ford Bronco Can't restart
128,000 MILES • 6 CYL • 4WD • MANUAL
THETANJ
My bronco would'nt start. So I changed the in tank fuel pump. It started and would run good. After driving for about 20 minuets and then turning it off, it would'nt start again. I let it set for a couple hours and it starts again. Someone suggested the control moduel? Any ideas?
Oct 23, 2008 at 8:17 AM
  • 75,988 POSTS
Hi thetanj and welcome to 2carpros
After driving for about 20 minuets and then turning it off, it would'nt start again. When this happens do below immediately
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Oct 23, 2008 at 8:23 AM
