1986 Ford Bronco bolts
87,400 MILES • 6 CYL • 4WD • MANUAL
BRONCO2CHARLES
how do i get a broken bolt off out of the flywheel in a 2.9 liter v6 need help
Aug 28, 2008 at 6:36 AM
DOCFIXIT
  • 18,828 POSTS
You could use a Easy Out Sears has them or a parts store. Drill pilot hole with small bit then drill hole the size recomended on Easy Out directions Am assuming you broke a cover bolt
Aug 28, 2008 at 6:56 AM
