1986 Ford Bronco alternator and voltage regulator
1986 FORD BRONCO
160,000 MILES • V8 • 4WD • AUTOMATIC
LITTLE_DEVIL666
I own a ford bronco full size with a 302ci fuel injected engine and automatic transmition, I need a new alternator and voltage regulator but have no idea what alternator or voltage regulator to uses, both of these parts are missing from the truck and when I tryed just buying new ones I was told there are multiple options for replacements, aswell as other systems that may be damaged I was wondering if there is some way of identifying whitch parts to use and if i can use any or only specific ones ?
Apr 15, 2010 at 4:52 PM
DAVE H
  • 13,384 POSTS
contact a ford dealer .. they should be able to tell you which type you need using the cars VIN #
Apr 15, 2010 at 8:40 PM
