1985 Ford Bronco Won't turn over
WJGARNER
  • 1985 FORD BRONCO
Electrical problem
1985 Ford Bronco 6 cyl Four Wheel Drive Automatic
I have been having issues trying to get my 1985 Ford Bronco to crank. When trying to crank it, I get absolutely nothing, not even any clicking. I have replaced the solenoid, and still can't get it to turnover. The only way that I am able to get it to turnover, is by placing a screwdriver on the solenoid, and then it will start. What could possibly be the reason why I can't get it to turnover by using the key? Any help would be appreciated.
Monday, September 8th, 2008 AT 2:12 PM
If you have power going to the ignition switch-The problem could be the switch itself, starter relay, neutral safety switch.
Hold key at crank position look for power at the red and light blue on the starter relay located at inner right fender-do you have it-let me know
Monday, September 8th, 2008 AT 2:23 PM
