My 85 Bronco will not start. The only thing that happens when I turn the ignition is that the starter will whine. this is the third starter that i have put on it the other two the brackets broke. I have tried to turn the motor by hand to see if it will catch a different spot on the flywheel but it doesn't. the flywheel is not damaged. i have also tried to jump the solenoid but still nothing.
Jan 4, 2008 at 9:52 AM
