I have a 1985 Bronco 2 that i got as a project car. we needed something to help haul and also i need to start learning more about how to fix cars. I got this and the starter is the major issue. the guy i bought the bronco from had a wood wedge jammed in next to the starter to make connection. the wedge fell out and when i turn the key, i can hear the starter turn, but it is not turning over the moter at all. i put the wedge back in and i heard a grinding sound and then it sounded like it was touching nothing again. i took the starter off thinking it was the problem, but the people at the autoparts store said i had the wrong bolts in it. i went on a hunt to find the "right bolts" 3/8 x 16 thread 37-45 mm long. but they were too short. the one bolt did not even fit into the opening under the bronco. so i ended up 5 hours later with basically the same bolts in it and the same problem. any ideas?
Jan 23, 2008 at 7:51 AM
