1985 Ford Bronco Problem starting
180,000 MILES • 6 CYL • 4WD • MANUAL
IMWOOKIE2
I just got this truck and when i picked it up it needed to be jumped (because it needed a new battery) but it ran fine and i drove it home. When i got it home I installed an new battery and now i cant get it started. It has power and its turning over when i try to start it its just not firing
Mar 20, 2010 at 12:11 PM
  • 75,988 POSTS
Did you have a check engine light come on or has flashed prior to this problem and when was your last tune-up?
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Mar 20, 2010 at 12:36 PM
