1985 Ford Bronco overheating after chang thermostat
1985 FORD BRONCO
54,000 MILES • 6 CYL • 4WD • AUTOMATIC
JCHAMBER
We changed the thermostat as well as the temp sensor still over heats I think I have an air lock in the engine do not know how to gwt it out
Feb 17, 2009 at 12:14 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Take radiator cap off then start engine. Let engine warm up to operating temp. then shut off. Refill coolant and let engine cool down. Repeat process as necessary. This will bleed the coolant system.
Thanks for using 2CarPros.com!
Feb 17, 2009 at 3:10 PM
