1985 Ford Bronco no brakes
GREGS1985BRONCO
Brakes problem
1985 Ford Bronco V8 Four Wheel Drive Automatic
new master cylinder, booster, front calipers, complete rear assembly, and new lines. have bled down starting from the passenger side rear to driver side front. I cannot get the bakes to work. Pedal goes to the floor.
Feb 14, 2010 at 2:04 PM
  • 75,988 POSTS
If there's no leakage anywhere and you adjusted the booster pushrod properly-I will recheck the master cylinder though it's new could be leaking internally-
Feb 14, 2010 at 3:24 PM
GREGS1985BRONCO
[quote:6de38f1cbb="rasmataz"]If there's no leakage anywhere and you adjusted the booster pushrod properly-I will recheck the master cylinder though it's new could be leaking internally-[/quote:6de38f1cbb]
Thanks for the help, kind of what I thought the problem was. After posting this question, I went back and took the lines off at the master cylinder, and used a brake vacuum pump to test for leaks, no leaks, it held 15lbs steady.
Next question;
how do you check the master cylinder for internal leaks? Or do I just take it back and exchange it?
Thanks again for your help.
Feb 14, 2010 at 11:30 PM
  • 75,988 POSTS
Take it back-You open it up and inspect the seals/cups-
Feb 15, 2010 at 5:18 AM
