1985 Ford Bronco ignition switch
150,000 MILES • V8 • 4WD • AUTOMATIC
GARYJOE_63
the ignition switch will not turn at all. i once couldnt turn it off when i got home but with a little pressure and wd-40 i got it to turn. that was a couple months ago and i had no problems till now. will i have to replace the swith or is there a fix for this.
Nov 28, 2008 at 3:41 PM
BLUELIGHTNIN6
  • 16,542 POSTS
WD-40 is the only temporary fix that I know of. Replacement is highly suggested. If you need instructions on doing it yourself, let me know and I will post for you.
Nov 28, 2008 at 3:54 PM
