1985 Ford Bronco fuel pump
200,000 MILES • 6 CYL • 4WD • MANUAL
FRANK T. MILLER
could I replace the mechanical fuel pump with an electric one safely as it would be a lot less work to put in the electric pump than to replace the mechanical pump.
Jun 3, 2008 at 4:25 PM
BLACKOP555
  • 10,386 POSTS
you cant do it without a kit to reduce the pressure of the fuel, if you dont it will get too much pressure and flood out the engine.
Jun 4, 2008 at 1:34 AM
