1985 Ford Bronco Caeberator
159,000 MILES • 6 CYL • 4WD • AUTOMATIC
DAVIDCOKER
I have a 1985 Ford Bronco with 159000 miles, standing at the front looking at the engine, on the left hand side of the carberator there is a red hose that connect to a metal tubing that runs to the back of the carberator that had came loose, we can not find where it goes and what it suppose to do?
Thanks
David Coker
Nov 1, 2009 at 9:51 PM
  • 110,251 POSTS
Can you tell where the other end is going to? Could it be running from an exhaust manifold to send heat to the choke thermostat?
Nov 14, 2009 at 4:44 PM
