1985 Ford Bronco
JOEY52
Engine Mechanical problem
1985 Ford Bronco 6 cyl Four Wheel Drive Manual
IT CRANKS OVER, THRER IS SPARK. I HAVE HAD COIL CHECKED ITS GOOD, I REPLACED THE IGNITION MODGULE, REPLACED CAP AND ROTER, IT STILL CRANKS BUT WONT START, WHAT SHOULD I CHECK NEXT. SHOULD I CHECK THE DISTRIBUTER AND HOW IS THAT DONE. OR WHAT DO YOU SUGGEST MY NEXT STEPS SHOULD BE. THANK YOU SO VERY MUCH.
May 7, 2008 at 5:46 PM
BMRFIXIT
  • 19,053 POSTS
turn key on
you should have check engine light on
if not check fuses and ignition switch and relays
check wiring connector on the coil
May 7, 2008 at 11:34 PM
