1985 Ford Bronco
LONEWOLFAK64
1985 Ford Bronco V8 Four Wheel Drive Automatic
it will not charge i have new alt new volt reg it has two hot wires and one ground wire and the alt is putting out 15 volts when tested but it still won,t charge the batt , some say i am missing a wire but i only took off the two set,s
Jan 7, 2010 at 3:15 AM
  • 110,251 POSTS
I believe the wire that goes from the alt to the battery is a fuseable link. Check it for continunity.
Let me know what you find.
Jan 11, 2010 at 11:24 PM
