Engine Mechanical problem
1985 Ford Bronco 6 cyl Four Wheel Drive Manual
IT CRANKS OVER, THRER IS SPARK. I HAVE HAD COIL CHECKED ITS GOOD, I REPLACED THE IGNITION MODGULE, REPLACED CAP AND ROTER, IT STILL CRANKS BUT WONT START, WHAT SHOULD I CHECK NEXT. SHOULD I CHECK THE DISTRIBUTER AND HOW IS THAT DONE. OR WHAT DO YOU SUGGEST MY NEXT STEPS SHOULD BE. THANK YOU SO VERY MUCH.
May 7, 2008 at 5:46 PM
