1984 Ford Bronco transmission slipping and buirning fluid
1984 FORD BRONCO
275,000 MILES • 6 CYL • 4WD • AUTOMATIC
JONAHBRAY
my transmision has been slipping but sometimes runs fine .. I otice it burns a lot of fluid and I see a huge cloud of white smoke come from my tail pipe a times .. also it tends to idle funny and dont want to un rite ... I can put it in park and then start again and it drives fine for a little while then starts idleing funny again and even backfires some .... could this be my Transmission Modulator Valve?? i thought I was just loseing a lot of fluidfrom a leak so I put some stop leak/ no slip additive in it and it seems to hav gotten worse ..
Dec 9, 2008 at 4:54 AM
2CARPRO JACK
  • 11,533 POSTS
The vacuum modulator would be a good place to start if it is burning white smoke and losing trans fluid. Unplug vacuum line at the modulator, if any trans fluid is present, replace the modulator. Be careful, there is a small rod int here that makes it work, be sure it is in there when you install the new one
Dec 9, 2008 at 7:53 AM
