1984 Ford Bronco Starter and solenoid
96,000 MILES • V8 • 4WD • MANUAL
84BRONCO
  • 6 POSTS
Im am currently work out a few bugs on my 84 bronco. Used to run fine then it wouldnt start or turn over but could push start it. I took to a mechanic said the new starter i had just put on was burned out and the solenoid as well. he said he replace about 4 solenoids on it. when crank the solenoid remain engaged but with a light tap it stops and will run. however the last time it wouldnt stop and i pull the key out and it kept running and died right there. Any ideas on what to do?
Jul 21, 2010 at 3:47 AM
KHLOW2008
  • 41,812 POSTS
Hi 84bronco,
Thank you for the donation.
1. Starter relay. Check if the starter relay is bad and sticking in the powered poasition.
2. Ignition switch. Check if the ignition switch is bad and not releasing from the START position even though the key has been turned off.
3. Starter gear. Ensure that the correct starter gear had been used. The wrong gear would result in the starter uverrunning clutch sticking to the flywheel ring gears and not releasing after the engine had started. This would destroy the starter within a few minutes.
Jul 21, 2010 at 4:24 AM
84BRONCO
  • 6 POSTS
would i need to replace the solenoid to check on the solutions you gave me
Jul 21, 2010 at 4:50 AM
KHLOW2008
  • 41,812 POSTS
Solenoids seldom gives problems and would not stick. They would only fail to work.
Have you replaced the starter yet? If yes, the solenoid should come with it.
Jul 21, 2010 at 5:45 AM
84BRONCO
  • 6 POSTS
Solenoid does not come with the starter it mounts seperately
Jul 21, 2010 at 7:27 AM
KHLOW2008
  • 41,812 POSTS
In that case the solenoid should be tested as well. Those mounted outside can stick.
Jul 21, 2010 at 7:47 AM
84BRONCO
  • 6 POSTS
what do you mean by correct starter gear is that the bendix? if so, would you just check by looks or do you measure some how?
Jul 21, 2010 at 8:19 AM
KHLOW2008
  • 41,812 POSTS
Starters have different number of gear teeth. If the wrong one was installed, could be due to wrongly supplie, then there would be problem as different number of teeth indicates a difference in the diameter of the gear.
You need to count the number of teeth and measure the diameter.
Jul 21, 2010 at 8:33 AM
84BRONCO
  • 6 POSTS
i replaced the solenoid because when i tried to start nothing happened also replace battery cable because of corrosion and wouldn't tighted. now when i crank it just clicked and battery cables got hot rubber even melted on partof it.
Jul 31, 2010 at 3:49 PM
KHLOW2008
  • 41,812 POSTS
This indicates something is shorted. If the cables becomes hot ONLY when the ignition switch is turned to START, then the problem lies between the battery cable installation point and beyond. Recheck the starter cable installation and reconfirm the starter is good.
Jul 31, 2010 at 8:18 PM
