1984 Ford Bronco how do I lower the idle
JAMES11
  • 1984 FORD BRONCO
  • V8
  • 4WD
  • 56,000 MILES
I need how to lower the idle level because my bronco's idle was set to high.
HELP
Tuesday, February 17th, 2009 AT 5:15 PM
BLACKOP555
  • 10,371 POSTS
First try to disconnect battery, leave unhooked a few minutes then restart it. After you restart it see if the idle will come down.
If that dont work you can back out the throttle adjustment screw found on the throttle body at the top of teh butterfly valve.
Sunday, February 22nd, 2009 AT 9:50 AM
