1984 Ford Bronco help
70,000 MILES • 6 CYL • 4WD • AUTOMATIC
UOISTHEDEVIL
just been overhauled 2.8 engine has power as long as in park put it in reverse it has no power at all it will not move everything is in time has no power in gears as long as its flat
Sep 23, 2009 at 7:06 AM
  • 110,251 POSTS
That doesn't make sense. Could the catylatic converter be plugged? Any major vacuum leaks? When you say no power at all, will it move the vehicle? Does it backfire, try to rev...?
Oct 23, 2009 at 5:12 AM
