1984 Ford Bronco
180,000 MILES • V8 • 4WD • AUTOMATIC
BEAUJ187
My 1984 Bronco won't start. I ran it a couple weeks ago, and it ran fine. Now it will turn over, but won't start. I changed the fuel filter and spark plugs. I poured gas into the carb and it still won't start. Could it be the timing chain broke? What would cause this?
Mar 17, 2008 at 6:06 AM
  • 75,988 POSTS
Check for power to the coil, the coil, distributor pick-up coil, and ignition control module and fuel pressure to nail the fuel pump-
Do this to verify an ignition problem-disconnect a sparkplug wire or 2 and ground it to the engine and have helper crank engine over-do you have a snapping blue spark? If not start checking above items-
Fuel problem-spray carb cleaner into the throttle body if fires up and dies out-start checking the fuel pressure-
Mar 17, 2008 at 9:12 AM
