1983Ford Bronco
MOVENYOU22002
Transmission problem
1983 Ford Bronco V8 Four Wheel Drive Automatic
Do I need a speciality tool to remove/replace/repair a front pump gasket on a C6 automatic transmission?
Apr 26, 2009 at 1:43 AM
  • 110,248 POSTS
Are you having trouble removing the pump? If so, you need to use a sliding dumbell. There will be threads in the pump itself that you will thread the dumbell into.
Jun 4, 2009 at 4:32 PM
