1982 Ford Bronco Stalling, rough idle
BRIAN F
Engine Performance problem
1982 Ford Bronco V8 Four Wheel Drive Automatic 79K miles
Having touble with stalling while coming to a stop and can't get idle set where I want it. Has a recenntly installed Holley 2 barrel carb which everything ran ok untill today. Also oil pressure seems pretty low on the guage(not sure if this is a seperate problem or connected somehow). All vaccum lines appear tight. Either runs rough at idle or will just stall altogether. I was thinking dirty or poor quality fuel also since it seemed to get worse after getting gas.
Feb 10, 2009 at 8:09 AM
  • 75,988 POSTS
Could be an A/F mixture improperly adjusted- PCV and EGR valves
Feb 10, 2009 at 8:29 AM
