1981 Ford Bronco
1981 FORD BRONCO
TEXAST82
I have a 1981, 351m, 200k, Ford Bronco. Awhile back I noticed the brake pedal getting soft, shortly after the brake light came on. When I checked the reservoir the front compartment was empty. I figured out I had a slow leak. I refilled the front reservoir and bled the back brakes. They have worked better then ever since then but now I can't figure out how to get the brake light off. Ya'll had told me to bleed the combination valve while holding in the pin on the front, but I don't know where to bleed the combination valve from? Any help would be great, thanks.
Nov 5, 2007 at 9:15 AM
All you have to do is block it open while bleeding all the brakes. You don't have to bleed the combination valve.
Or you might want to apply excessive force to the brake pedal to equalize the pressure.
Nov 5, 2007 at 9:55 AM
