1980 Ford Bronco
ROHN08
Engine Mechanical problem
1980 Ford Bronco V8 Four Wheel Drive Manual
is there a trick to getting ttthe fuel pump back in a 1980 ford 351 m
Mar 26, 2009 at 9:19 AM
DOCFIXIT
  • 18,828 POSTS
Kind of the actuator rod needs to be on back side of cam ecsentric. Feel fro rod rotate engine untill it moves up then take a globe of grease put it on rod will hold until pump is bolted on.
Mar 28, 2009 at 5:43 AM
