the bronco has spark when you first turn the key over. Then it goes away shortly after once you let off the key it has a spark momentarialy
Mar 13, 2010 at 10:42 PM
✓Experienced Mechanic
Power the coil from the battery positive post to the coil positive terminal if it continues to run check and test the resistor wire and ignition switch.
