1979 Ford Bronco engine will not stay running
12,700 MILES • V8 • 4WD • MANUAL
BIGWALLY
79 bronco .new fuel pump, rebuilt carb, will start upon cranking then die as if no gas , when you pump it during cranking it goes .brum brum brum and dies, fuel level in carb is correct.no fuel line collapse, recently cleaned gas tank,new cap and rotor, plugs and wires.recently died on the road and restarted by itself upon coasting. engine was rebuilt 46,000 mi ago
Jan 12, 2008 at 4:51 PM
  • 75,988 POSTS
Gunny, I need the pick-up coil resistances on a 1996 dodge pick-up distributor any pick up will do-am on a notebook cannot acess it-wil you pretty please! good Boy thanks Homie send it PM
Jan 13, 2008 at 10:29 AM
