1979 Ford Bronco engine acting wierd
105 MILES • V8 • 4WD • AUTOMATIC
DOPEASSADAM
my motor was just rebuilt from a 351M to a 400 it has no more then a hundred miles on it and i was out in the desert and i came down pretty hard off a ditch and now everything feels fine until i really get on the gas then it kind of struggles as if it was missing, i recently changed the wires as well
Mar 18, 2009 at 4:38 PM
  • 75,988 POSTS
Engine hesitation could be caused by the following:
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Mar 18, 2009 at 7:55 PM
