1979 Ford Bronco V8 Four Wheel Drive Automatic
ive got a 79 bronco with a 351. It was running low on oil so I added some oil and some lucas oil stabilizer. Since then it seems like I have recieved a noisy lifter or rod. I pulled the valve cover gasket and checked the rod's for being bent and they were all ok. I also added some enging flush ran the motor and then flushed and changed the oil and did not seem to help. Any suggestions? How do I know if it is a lifter?
SPONSORED LINKS
Saturday, September 26th, 2009 AT 8:58 PM
