1978 Ford Bronco Leaking
ZTRABUN
Engine Mechanical problem
1978 Ford Bronco V8 Four Wheel Drive Automatic ??? miles
I bought a 1978 Ford Bronco. It is leaking oil from the valve cover gasket, the transfer case (front and rear), and the axles. I was wondering what kind of costs I am looking at to repair these problems
Jun 25, 2010 at 8:27 AM
  • 110,251 POSTS
If you are doing it yourself, I would say parts will be under 100.00. If you add labor to it, I would add about 5 hours labor (based on where it is leaking from the transfercase).
Jun 29, 2010 at 4:55 PM
