1978 Ford Bronco ignition
222,000 MILES • V8 • 4WD • AUTOMATIC
FORD88
im currently working on a 1978 ford bronco and ive replaced every part of the ignition system. when i turn the key to the on position it trys to start and while its doin that i can turn it off and take the key out and its still trying to start so i have to jump out and disconnect the battery and with everything off i go to reconnect the battery and it trys to start again. what should i look at and what would cause it do do that?
Jun 4, 2008 at 7:37 AM
BMRFIXIT
  • 19,053 POSTS
Check the starter solenoid at the fender and make sure starter switch is at the S terminal
Jun 12, 2008 at 2:15 PM
