reset timing checked all vacum lines put new spark plug wires on engine backfires under load
Jan 7, 2010 at 2:51 AM
✓Experienced Mechanic
Have you checked engine compression? You may have a burnt valve. Also, are you sure you are getting a good hot spark, and where does it backfire from the exhaust or intake?
