1966 Ford Bronco
JIMBO D
Engine Performance problem
1966 Ford Bronco 6 cyl Four Wheel Drive Manual ? miles
What would make fuel spit out of the 1 barrel carb and run ratty after I hit a rock (Big rock) plowing snow? Timing?
Jan 9, 2009 at 11:28 PM
MIKE H R
  • 3,094 POSTS
If you did not do any damage to the engine, I would suggest check all the wiring. With fuel pulsating out of the carb I would do a compression check, The possibility could also be the float in the carb is letting it get too much fuel.
Jan 21, 2009 at 1:07 AM
