1995 Ford Aspire Need Help ASAP
MARCIA CRANMER
Engine Mechanical problem
1995 Ford Aspire 4 cyl 565812 miles
I was driving down the road and my car shut down, it has gas, oil and didn't overheat. Tried to start it engine turns over but does not start,,,,tried to push it then pop clutch and still didn't start...i just bought this as used car less then 2 mons ago and am making payments on it,,,,,,please help me i have to work tomorrow. Thank you very much. Marcia Cranmer
Apr 14, 2010 at 10:21 AM
  • 75,988 POSTS
Hi marcia cranmer,Welcome to 2carpros and TY for the donation.
Do below to determine whether it's a fuel or spark issue:
Cranks but no start condition:
Fuel and Spark
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/COP/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Apr 14, 2010 at 12:39 PM
