HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Aspire
Engine
Symptoms
Not Running
SPONSORED LINKS
1995 Ford Aspire fuel system
HOOLIGANVA
MEMBER
1995 FORD ASPIRE
Engine Mechanical problem
1995 Ford Aspire 4 cyl Front Wheel Drive Automatic
where is the fuel pump located and the car wont start but when you push on the gas tank the car will start
Friday, June 20th, 2008 AT 9:45 AM
PURZNER
MEMBER
The fuel pump is located in the gas tank.
https://www.2carpros.com/forum/1995-ford-aspire-fuelpump-vt159273.html
just explained to a guy some basic steps on changing one. that might help you find your fuel pump.
but you do sound correct it sounds like the motor in the pump is probally starting to throw fits at you :(
SPONSORED LINKS
Tuesday, July 22nd, 2008 AT 11:43 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1995 Ford Aspire Engine Cranks Will Not Fire
I Have Replaced The Distributor From A Running Engine Of The Same Model Vehicle. 1995 Aspire Will Crank But Will Not Fire
Asked by
elbo55
1995
FORD ASPIRE
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
Will Not Start
This Car Is Driving Me Completely Insane. 1.3 Engine, 125,000 Miles. Will Not Start Here Is The Quick Version: (long Version Below) ...
Asked by
Benz_Guy
1995
FORD ASPIRE
1995 Ford Aspire Engine Cranks But Will Not Start
I Bought A 95 Ford Aspire That Was Rolled Over. Since The Roll Over, The Inertia Switch Has Been Reset And The Car Has Been Driven. When...
Asked by
slmannon
1 ANSWER
1995
FORD ASPIRE
1995 Ford Aspire Wont Start
Okay My Aspire Was Running Fine Then It Sputtered And Died. It Is Cranking Good. I Disconnected Fuel Line From Filter And It Is Definitely...
Asked by
wickitiwack
1995
FORD ASPIRE
96 Ford Aspire Will Not Start Or Make A Sound
A Week Ago My '96 Ford Aspire Clonked Out. It Wouldnt Start Actually. It Was In The Driveway. And It Wouldnt Start, When I Turned The...
Asked by
f0rdssuck
1 ANSWER
1996
FORD ASPIRE
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Symptoms
Crankshaft Sensor Replacement
Online car repair manuals
