1994 Ford Aspire stall when put in drive or reverse
1994 FORD ASPIRE
17,500 MILES • 4 CYL • 2WD • AUTOMATIC
RASSY
1994 Ford Aspire will start and idle, but then stall when put in drive or reverse even sometimes I can put it in drive and move the car as long as I don't give it gas.
Jan 24, 2010 at 9:48 AM
  • 110,244 POSTS
Have you checked for vacuum leaks? Has the check engine light come on? Have you checked fuel pump pressure?
May 1, 2010 at 7:40 AM
