1994 Ford Aspire Loud Front End Noise
157,000 MILES • 4 CYL • FWD • MANUAL
FIREBIRD623
have vibration and growl in front end at all speeds. goes away only when turning hard left. 1st thought was wheel bearings. replaced those,new tierod end and lower control arm/ball joint and new cv half shaft. still no change in sound.it vibrates the dash...etc. any thoughts ????. tried one fix to test it and it worked but not sure what it changed. installed a festiva control arm that was 1/2 inch shorter. it changed the tire camber some and tested it on side road. all quiet no vibration nice and quiet ?. could it be a differential bearing ?. any thoughts greatly appreciated. thanks
Sep 11, 2010 at 4:23 PM
  • 110,248 POSTS
It sounds like a wheel bearing. Did you replace both sides?
Oct 15, 2010 at 3:06 PM
