Four cylinder front wheel drive, automatic, 190,000 miles.
I am trying to locate the fuel pump relay in this car, and I have no luck whatsoever. Is it the little black box under the column or a white one to the left of the brake pedal? Or is it under the hood somewhere? Tested the fuel pump directly, not going through relay and it works, so the relay is bad or something else, but what? Please help, need to go to work.
Jun 3, 2010 at 5:22 AM
