1994 Ford Aspire car stalls while moving or idle
1994 FORD ASPIRE
263,000 MILES • 4 CYL • 2WD • AUTOMATIC
94GREENGRILL
How can you test to see if this is a fuel problem or electrical problem? If it is a fuel problem, how do you figure out if it is fuel filter or fuel pump?
Oct 17, 2010 at 10:50 AM
  • 110,194 POSTS
You need to check the fuel pump pressure. First you can check it at the engine and then before the fuel filter to see if there is a problem. Here are the directions for checking. It also includes how to check the fuel pressure regulator. Let me know if it helps.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Nov 6, 2010 at 1:49 AM
