Sliding door won't open '96 Ford aerostar
1996 FORD AEROSTAR
MEBEJEAN_ASS
what do I do to get the sliding door open on a 96 ford aerostar? t worked fine but jsut stopped opening. it's like the handle goes down and makes the opening sound, but the back end won't kick out. help
Oct 10, 2007 at 5:44 PM
WARDEAUX
if while you pull the handle to open the door you push on the back of the door from the inside does it open or does it seem the latch is still engaged? If the latch is still engaged, I'd say either the latch is broken or the handle has become disconnected to the latch...
hope this helps...
wardeaux
Nov 9, 2007 at 5:14 AM
