Ford aerostar losing power
FORD AEROSTAR
SHERRY12
1998 ford aerostar, 194, 000 miles. While I was driving along, my battery light came on, then within a few min the battery guage that shows the power started to fall down indicating a lack of power, my lights went dim and when i turned on the highbeam headlights the speadomitor fell to "0" but i was still moving. I shut off the heater and the radio and then the speadomitor went back up again.The van finally shut off in my driveway, but an hour later I could start it again. What would cause this?
May 14, 2007 at 2:23 AM
BLACKOP555
  • 10,386 POSTS
make sure you do not have a loose groudn somewhere or corroded battery terminals.
May 14, 2007 at 3:00 PM
SHERRY12
Thanks alot, I'll give this a try. I will let you know if it works
May 14, 2007 at 11:30 PM
SHERRY12
I found the problem it was my altinator, i have replaced it but now the van starts when i put the battery lugs back on, even without the key in the ignition. OH mY, i don't know what would casuse this to happen, i have remote start would that have anything to do with it?
May 16, 2007 at 2:08 AM
