Aerostar 97 cranks but wont start
1997 FORD AEROSTAR
HRDINAS
The van failed to start three times when temperature is 0 F. Second stall, I added jumper cables and unit started up. Ran fine for 12 miles, parked in garage change filter and started up with no issue. Test drive was fine. Parked outside and will not start. Did sputtor. Any simple location to add a fuel pressure gauge. I am guessing the pump is defective ? No error codes. 3.0 Liter 145K miles.
Starter cranks engine over without any problem.
Feb 5, 2007 at 2:50 PM
HRYK2646
  • 40 POSTS
Might check battery .cold will affect the battery make it hard to start .Cold cranking amps the higher the better.Is battery old?
Ray
Feb 9, 2007 at 5:04 AM
RON2_1
  • 5 POSTS
Let me know how you make out with this problem. My 97 Aerostar is doing the same thing. I thought it was the Coolant Temperature Sensor so I changed that but it still does the same thing. Something is telling the computer not to turn on the fuel pump.
Also is your Overdrive light on when you turn the key on before starting?
Feb 12, 2007 at 1:31 PM
RON2_1
  • 5 POSTS
Found the problem with mine. Turned out to be the Air intake Temparature Sensor.
Check that. Mine was doing the exact same thing
Feb 23, 2007 at 12:26 PM
