My A/C is blowing out the defroster vents, not the dashboard vents. Help!
Aug 16, 2008 at 7:10 AM
KHLOW2008
✓Experienced Mechanic
Hi alanddavis,
You need to check the vent linkages and adjustment. Is the control adjusted to the correct position?
Aug 16, 2008 at 3:20 PM
ALANDDAVIS
MEMBER
I'm pretty sure the linkage is okay, but I'll try to check it. Thanks.
Aug 18, 2008 at 4:57 AM
check the vacuum source tube, it is probably broken causing the vent to stay in the defrost position.
Sep 16, 2008 at 10:18 AM
ALANDDAVIS
MEMBER
Thanks. I found a little critter had made a home in the blower motor. I pulled out a nest and had to repair the vacuum hose. It's working fine now.
Sep 16, 2008 at 11:10 AM
