Kevin
I forgot to be more specific about the starting itself. The van cranks over just fine. Battery and alternator are in good condition. To me it seems like a fuel problem, but I could be totally wrong. I hope you can help me.
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
If adding a follow-up, state whether reliable starting continued and provide any existing diagnostic findings for the separate shifting problem.
Source: Original question and visible replies. Owner reports and other participants' experiences are distinguished. Next steps are editorial requests for clarification or existing diagnostic findings, not a verified repair procedure or an independently confirmed component diagnosis.
93 Ford Aerostar Starting Problem? HELP!?!
The poster described intermittent starting trouble with their mother’s 1993 Ford Aerostar 3.0L. The engine cranked normally but sometimes would not start after a short stop, while longer waits allowed it to start. The poster later reported that replacing the ECT sensor resolved the starting problem, then raised a separate transmission-shifting concern.
Reported outcome: The poster reported successful repair of the starting problem after ECT sensor replacement. The later transmission concern remained unresolved in the thread.
This is a reported repair outcome, not an independently verified diagnosis. Another participant’s wiring repair concerned a different Aerostar. The thread does not establish a connection between the sensor replacement and the transmission concern.
